ScottEOsborn
Dec 03, 2022Aspirant
Have to reset my router every other day
I got the Orbi AXE11000 (3 RBKE963B units) and it's worked great - up until 2 weeks ago. Now my network goes out every other day and can only be fixed by resetting (power-cycling) the router. To ...
Dec 03, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
ScottEOsborn
Dec 04, 2022Aspirant
Thanks for the reply Furry. Pretty sure I'm using the orbi system in the proper way - notice that it has worked perfectly fine for over a month - the question is "does anyone else experience this?"
