ScottEOsborn
Dec 03, 2022Aspirant
Have to reset my router every other day
I got the Orbi AXE11000 (3 RBKE963B units) and it's worked great - up until 2 weeks ago. Now my network goes out every other day and can only be fixed by resetting (power-cycling) the router. To ...
ScottEOsborn
Dec 04, 2022Aspirant
Thanks for the reply Furry. Pretty sure I'm using the orbi system in the proper way - notice that it has worked perfectly fine for over a month - the question is "does anyone else experience this?"
Dec 04, 2022Guru - Experienced User
Well maybe however something may have changed. Might be a good idea to give feedback on the questions presented so we can help you figure this out. There are also subtle factors that can contribute to Orbi not working right.
I haven't seen anyone else complain about this and also I saw 16days of solid uptime on my 9 series:
- ScottEOsbornDec 04, 2022Aspirant
Thanks for the reply, then I can say it's either my hardware or how my network is set up.
FWIW I'm on the latest firmware (for both router and satellites) 6.3.7.5_3.2.25.
