Sir_oclaF
Jul 10, 2024Aspirant
Having issues adding 2 pack to newly set up 3 pack
I just purchased an AX6000, 3 pack, over the weekend and set it up successfully with zero issues. Guess I wrongly assumed that adding a 2 pack of the same generation would be as seamless… I’ve tried m...
Sir_oclaF
Jul 11, 2024Aspirant
Ok sounds simple enough, but am I able to do this the simplest way I see using just my phone by adding a new orbi system, with the new router and sat. To update the firmware, via the app. And then removing them
From that new network and try adding them
As additional Sats to the existing system with my first 3?
Jul 11, 2024Guru - Experienced User
Ya set up the 2nd system normally and get the RBS updated.
Might give this a try with a wired PC or laptop but if phone and orbi app work to get that system online and updated, go for it.
- Sir_oclaFJul 11, 2024AspirantGotcha, going to try with my phone first bc it seems to be doing fine. But if I can’t successfully for some reason will use my notebook. Now the question is, once I finish setting up the secondary systems router and sat. I’ve already updated firmware on router, will see if it does it for Sat when it finds it. But after that is all done do I then just go back to first system and steal them away by just clicking add Sat for each? Or is there something else left to do? Sorry for the questions, hoping this isn’t too big of an issue..
- FURRYe38Jul 11, 2024Guru - Experienced User
Yes, you'll need to disconnect the 2nd set of RBS from the RBR. Them put the 1st RBR online, I'd leave the 1st set of RBS OFF. Then with the 2nd RBS set in same room as 1st RBR, sync them using the RBRs Add Satellite feature. One at a time.
- Sir_oclaFJul 11, 2024AspirantOk! Of course the second RBR updated fine but wasn’t able to find its included RBS. Tried several times. The second RBR/S pack I bought is just 2 units, an rbr and rbs. So I reset them to try again. I figured it would have to find its RBS and update the firmware on it also, but maybe I just caused myself another painful pointless step by assuming.
