iainb123456
Apr 24, 2022Aspirant
Help - Massive loss of speed from Orbi Satellites using Wi-fi
Hi, I have an RBS850 router with 3 RBS850 satellites and 3 RBS750 satellites. Our house is 4,500ft²+ with large garden which requires wi-fi coverage for CCTV etc. The house is 350 years old so ha...
Apr 26, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Are the RBS wireless connected to the RBR?
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
