JA99
Jul 13, 2020Follower
Help Build Home WiFi Mesh For Cox Gigablast
I'm hoping for help. I'm upgrading to Cox Gigablast and want to install Orbi RBK853 WiFi 6 System for a wireless mesh. I've looked at the Cox website to see what modems are compatible with Gigablast,...
Jul 16, 2020Guru - Experienced User
Let us know what you end uo getting...
JA99 wrote:I'm hoping for help. I'm upgrading to Cox Gigablast and want to install Orbi RBK853 WiFi 6 System for a wireless mesh. I've looked at the Cox website to see what modems are compatible with Gigablast, and the CM1200 Nighthawk is on the list. Are there connectivity/compatibility issues between the modem and router models noted? If seamlessly compatible, is the CM1200 modem a good choice for the Orbi router mesh noted above? My home network is used primarily for internet surfing, TV streaming, and gaming. We do not currently use voice activated devices.
I appreciate your feedback.
