JayD83
Sep 30, 2023Follower
Help needed - New Orbi is 3x slower than Old Orbi (Wired & Wifi)
Hi all Any help here would be brilliant I use to run Orbi RBK50 and 2 satellites using Virgin media 500meg broadband. When wired via ethernet I was actually getting above this speed at roughly 600...
Oct 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
