domnik968
Apr 19, 2025Aspirant
Help needed setting up Orbi RBK752
I recently moved into a place that has AT&T fiber and a bwg320 gateway box but I would prefer to use my Orbi mesh setup. I can’t seem to figure out how to set it up. Does anyone have any tips?
CrimpOn
Apr 19, 2025Guru - Experienced User
The easiest method is to connect the RBR750 router to the BGW320 Gateway and proceed to set up the Orbi system using a computer connected to the Orbi router. (Or the fancy Orbi 'app' - ugh)
This results in two WiFi routers, so most customers will choose to turn off the WiFi on the BGW320 system.
