libru97
Dec 27, 2022Follower
Help needed! Why don't I see devices connected to a switch? RBR750 with 2x RBS750
My network: RBK753 series, 1 RBR and 2 RBS nodes. RBR is directly connected to the modem ofc, 1 satellite only has a wired connection to a desktop, 2nd satellite has a switch connected (currently a ...
Dec 27, 2022Guru - Experienced User
Maybe due to having a managed switch. Try a non managed switch:
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Also recommend CAT6 lan cables as well.
Also be sure that host names of devices don't have any special characters in the name. Seen this hose up the system. I think underscore and dashes are ok.
RBR is directly connected to the modem ofc, 1 satellite only has a wired connection to a desktop, 2nd satellite has a switch connected (currently a Netgear GS305E). However, for some reason I don't see any connected devices behind the GS305E, from time to time for a brief moment I do see the GS305E, but nothing else connected to that switch. Is this how it is?
Every device connected to the switch is online and working, the log on my RBR is even giving them DHCP leases. But the connected devices behind the switch never shows up in connected devices, which doesn't allow me to reserve the IPs etc.
