hewire44
Mar 02, 2023Follower
Help Orbi 753 system problems
Just bought the Orbi 753 system, I have a modern/router from my ISP. Connected via webpage and changed to AP mode which worked ok but unable to add satellites, they were just showing purple lights de...
Mar 02, 2023Guru - Experienced User
Usually if the led's on the satellites are blue it means they linked.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Did you try hardwiring the satellites into the router and syncing them for a period?
