detroitsandman
Oct 16, 2023Guide
HELP!!! Orbi 960 Series AXE11000 | Hardwire speeds of router and satelite fine, wifi drops randomly
Hello, I have a NETGEAR - Orbi 960 Series AXE11000 Quad-Band Mesh Wi-Fi 6E System (3-pack) - White and have had it for about 11 months with an extra satelite. (In a 2500 sq foot home). It w...
Oct 17, 2023Guru - Experienced User
Disable Armor thru the Orbi app.
Remove the Check mark from the box then select apply.
detroitsandman
Oct 17, 2023Guide
There is no checkbox in the app... (that would make too much sense). Just getting me to try and buy more of it.
rebooted the router and satellites still wont connect. The app says no satellites connected, they have no LEDs lit meaning they should be normal? (I see the blue LED now actually, but that goes away) I feel like it is slowly dying overall.
Should I reset the satellites to factory and try and add them back? I have synced them a couple of times, but they are not registering in the app or in the interface through hardwire.
