Jamie9558's avatar
Jamie9558
Follower
Jan 31, 2024
Help pairing rbs350 to rbr750
I have an exisiting rbr/rbs 750 system they work well I was able to pickup some rbs350 from a friend cheap and the website says they are compatible however o can't seem to getbth to sync, both unit are almost next to each other press the sync buttons go through the app not working please help
  • plemans's avatar
    Try hardwiring in the satellites and syncing them.
  • FURRYe38's avatar
    What Firmware version is currently loaded on the 750 series system? If v7 FW, this is not compatible with 350 series RBS.
