Warlord888
Nov 06, 2020Aspirant
Help Please... Wifi 6 with 4G Lte Failover
Hello all, My smarthome is expanding and now my existing Nighthawk X10 R9000 is failing to keep up, unfortunately. I've done the Netgear "Find my Orbi Router" questions... It appears I ne...
- Nov 06, 2020
Something that isn't suported on Orbi systems or most any home class router.
Failover is mainly for business or enterprise class environments. You'll need to check into one of these classes for failover features.
Good Luck.
Nov 06, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Thats a lot, ya I would say and orbi system with at least two RBS. Three maybe, howver placement and distance will need to be observed.
Warlord888
It's a relatively small 3 bedroom detached house in the UK, but my main issues are volume of IP addresses and the sheer amount of devices connected at any one time.
The satellites would most likely be no more than 20 feet apart from each other.
The reason why I was looking at 2 satellites and not one, was mainly because I need to hardwire my IP Phones into the main router in my office. There's a 'black spot' right in the middle of the house on the 1st floor (the boiler room) which is has alloy heat shielded walls. It causes connectivity issues between the Kitchen and the current router position.
I was then going to hardwire my TV and PS5 into another satellite in the Living Room
I was then going to hardware my Sons PS5 into another satellite in his bedroom
Basically we still enjoy gaming and I wanted the best / fastest speeds for us all without compromising anything
Steve
