shellieg1
May 16, 2022Aspirant
help..RBR750 lost connection to satellites
oh please help me..somebody with a brain that is working better then mine right now LOL. I am SO frustrated with this system right now. Last night, the connection between one satellite (That happens ...
May 16, 2022Guru - Experienced User
Might need to factory reset the RBR and RBS and setup from scratch.
- shellieg1May 16, 2022Aspirant
Thank you for reaching out to me. I am at my wits end. Why does everything run smooth;y for months and then ..bam..
Firmware v4.6.5.14
My internet provider is comcast/xfinity and I am using my own modem/ Arris surfboard T25
Connected by cable/coax
I have tried a factory reset and the router is discovered but none of the satellites.
At least I pressed the factory reset button on all of the devices. Thank you for your help. I really appreciate it.
Rachele
Oh..I also am trying to hook up without using my flashed netgear nighthawk router but still only the router shows up. grrrrrrr
- FURRYe38May 16, 2022Guru - Experienced User
If the RBR is setup, bring one of the RBS to same room as the RBR.
Use the RBRs web page to add a RBS using a web broswer. Follow the instruction on the RBRs web page for adding a satellite...
See if the RBS can be added here.
Hi,
Yup..Tried that and it starts to add going as far as resyncing but then it fails. I am so lost here. You are so nice helping me out.
Thanks again
Rachele
