cuthagoo
Sep 16, 2021Aspirant
HELP!!! RBR850 Router with 2 Satellites will not reconnect after factory reset
I have the RBR850 Router with 2 Satellites, current FW is V4.6.3.16_2.0.51. I got these a year ago in Oct and everything has worked perfectly with no issues at all until today. This morning the rou...
cuthagoo
I walked through the setup process via the hardline like you suggested. I set up a new SSID and password, but it can't be found on any devices. I also have the router and the satellites all in the same room right now, maybe 6-8 feet apart, and doing sync does nothing... any ideas?
Sep 16, 2021Guru - Experienced User
I recommend you contact NG support and let them know what or having problems with.
You can open a support ticket here:
- cuthagooSep 16, 2021Aspirant
The only problem with that is I only had 120 days of tech support from purchase, now to contact tech support they want me to pay for premium support? Or is there something I'm missing in how to contact them on this? It says my warranty is good through Oct. 21, 2021, so a little over a month left. Thanks!
- FURRYe38Sep 16, 2021Guru - Experienced User
Please send Darren and Christine a PM.
