sdcontre
Jul 27, 2020Initiate
Help setting up VPN service on iOS or MacOS. (RBK852)
Hello, I'm trying to set up the VPN connection on iOS or MacOS to connect to my home network from a remote connection. I enabled the feature in the web controls and downloaded the prompted zip fo...
- Aug 14, 2020
I've just got this working.
On the mac with your iphone plugged in, open finder and click on you phone on the left side.
Then click files along the menu towards the right
then expand openvpn
then open another finder window and go to your Downloads/smarthpone folder and drag all 4 files from it to openvpn (ignore the inbox) in the other finder window.
then open openvpn on your phone and you should see it there to import.
sdcontre
Added the files via Windows iTunes but profile won't connect. I feel like I'm missing a key step somewhere.
- parisvAug 14, 2020Tutor
then expand openvpn
