Colin_523
Aug 03, 2021Aspirant
HELP! Slow WiFi on RBR850
Desperate for some help, this system is driving me mad! I've got the RBK853 - AX6000 Router and 2 Satellites The router is plugged into the service provider modem with a Cat 8 cable. On the Orbi...
Colin_523
Aug 07, 2021Aspirant
Ok, thanks.
My iPhone and MBP are in the same place and connected to the same satellite. MBP link rate is 1170Mbps, iPhone is 720Mbps. MBP is getting about 30% of that and iPhone about 37%.
The link rate in my iPhone app is Network Map / Click on the Orbi connected to / Click on the device in the list
My head hurts!
raven_au
Aug 07, 2021Virtuoso
Colin_523 wrote:Ok, thanks.
My head hurts!
It's probably a silly question but have you (on the iPhone) forgot or reconfigured (on the MBP) the wireless association?
It probably won't help but should be fairly straight forward to try.
In the past the claim is that there can be information about a previous wireless connection that isn't ok for a connection to a different device. I'm not certain that's right but when I first started using AX based routers I started seeing router reboots and after going around and resetting connection on devices a couple at a time, easiest first (mobiles, TV's etc.), the reboots eventualy actually stopped happening, odd I must say.
So perhaps this is worth trying.
- Colin_523Aug 08, 2021Aspirant
Tried Googling this and can't find anything on it, so no idea where to start.
