yunnun
Sep 03, 2023Follower
Help trying to isolate a speed issue
Hey all! I'm having some trouble with my Orbi RBR850/RBS850 system, specifically with the speeds on one of the satellites. The satellite in question is connected to the RBR via ethernet however I am...
Sep 03, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router and RBS. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly or wire connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
️Have you swapped RBS with each other to see of problem follows the RBS?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
