p0se1d0nX
Sep 10, 2021Star
Help w/ Configuring IPv6 on RBK852
Hello. Just purchased the Orbi RBK852 mesh system and it works great - except for getting IPv6 to work. My ISP is Spectrum and I’m using CloudFlare. The Netgear IPv6 drop-down selection offers many...
Sep 10, 2021Guru - Experienced User
Your ISP will have IPv6 recommended configurations to use on routers. Some may use Auto, DHCP or something more specific. They should be able to direct you to which on to use. I was using DNS 6to4Tunnel since my ISP doesnt' support native IPv6. That work well for me.
After making changes and saving them, Try a full reboot of the RBR and ISP modem.
- p0se1d0nXSep 10, 2021Star
I have the Arris S33 3.1 Docsis cable modem with Spectrum Ultra (450/22) internet service.
I'm not sure which drop-down IPv6 selection to choose w/ Cloudflare DNS?
If anyone else also has Spectrum ISP, please let me know what works. Thanks
- FURRYe38Sep 10, 2021Guru - Experienced User
Use the RBRs web page to see additional information for IPv6.
Contact the ISP to see what they recommend using.
- plemansSep 10, 2021Guru - Experienced User
Did you try auto-detect?
It might just work with auto-detect.
Then you can set your cloudfare address.
You'll also want to change it on the standard "internet setup" page for the IPv4 to cloudfares DNS address.
