Pkkz124
May 11, 2024Aspirant
Help w Orbi RBR750 internet connectivity issues
Having trouble with my Orbi RBR750 purchased in 2021. Recently had my router constantly turning ‘purple’ and not connecting to my internet. I reboot the system and it works for a few hours but then do...
May 13, 2024Guru - Experienced User
Usually if its purple/magenta, it can't connect to the internet.
What modem/gateway is it connected to?
When it turns magenta, are you still able to connect to the orbi and view its GUI?
What does it show under the internet connection?
- Pkkz124May 13, 2024Aspirant
I've had to constantly reset the router when it turns Magenta. It then works for a few hours, but then doesn't work again. I basically have to constant reset the ORBI Router. definitely something with the router and not my modem or internet which is working fine.
- plemansMay 13, 2024Guru - Experienced User
Which didn't answer a single question I asked and specifically avoided them.
Troubleshooting isn't a "click this and its fixed". Its figuring out a users setup to see what could potentially be causing the issue. I've got a 750 series running on spectrum and its been rock solid in its stock setup. But we know nothing about your setup
- FURRYe38May 13, 2024Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter and IPv6.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.- Pkkz124May 13, 2024Aspirant
thanks for this suggestion.
I updated to the latest firmware manually yesterday (version 7x) on both the router and satellite and that did not fix the problem.
I'm connected to a Metronet modem (has been on this SAME set up for 2-3+ years without a problem until now) that seems to be working properly. And its strange everytime i reboot the router, it works fine for a few hours and then 'goes out again'.I am going to try the factory reset later today when i'm home and see if that works.
appreciate the help. I am really not a IT person at all, so its all new to me.
