Pkkz124
May 11, 2024Aspirant
Help w Orbi RBR750 internet connectivity issues
Having trouble with my Orbi RBR750 purchased in 2021. Recently had my router constantly turning ‘purple’ and not connecting to my internet. I reboot the system and it works for a few hours but then do...
May 13, 2024Guru - Experienced User
Usually if its purple/magenta, it can't connect to the internet.
What modem/gateway is it connected to?
When it turns magenta, are you still able to connect to the orbi and view its GUI?
What does it show under the internet connection?
Pkkz124
May 13, 2024Aspirant
I've had to constantly reset the router when it turns Magenta. It then works for a few hours, but then doesn't work again. I basically have to constant reset the ORBI Router. definitely something with the router and not my modem or internet which is working fine.
