Pkkz124
May 11, 2024Aspirant
Help w Orbi RBR750 internet connectivity issues
Having trouble with my Orbi RBR750 purchased in 2021. Recently had my router constantly turning ‘purple’ and not connecting to my internet. I reboot the system and it works for a few hours but then do...
Pkkz124
May 13, 2024Aspirant
I've had to constantly reset the router when it turns Magenta. It then works for a few hours, but then doesn't work again. I basically have to constant reset the ORBI Router. definitely something with the router and not my modem or internet which is working fine.
May 13, 2024Guru - Experienced User
Which didn't answer a single question I asked and specifically avoided them.
Troubleshooting isn't a "click this and its fixed". Its figuring out a users setup to see what could potentially be causing the issue. I've got a 750 series running on spectrum and its been rock solid in its stock setup. But we know nothing about your setup
