Misterg911
Nov 21, 2024Follower
Help with configuration
Hi, I have an RBR860 router/two RBS860 satellites. My home has solid block walls and concrete ceilings. These products only just do the job in the house, but not the kitchen, so I have run ethernet cable to the kitchen. I have built a new garage separate to the house and have run ethernet cable to downstairs and upstairs. So now I need three units for the end of each of the 3 ethernet cables. What do you recommend please? Because I now have cables can I use something less expensive than the 860?
1 Reply
Can try using Power Line adapters to get LAN services to remote locations.
If you need more LAN port usage, you can connect a non managed switch to the back of the RBR, then connect the RBS to this switch. NGs GS105/108 or GS305/308 would be recommended. 5 is a 5 port while the 8 is a 8 port versions.
