nashdm2
Aug 29, 2022Aspirant
Help with new mesh purchase
Hi all, I am looking at buying a 1 x RBR850 and 3 x RBS850 kit. I plan to connect them all up with ethernet cables and run it off a virgin hub in modem mode. I am very sorry if these things have bee...
CrimpOn
Aug 29, 2022Guru - Experienced User
1. Yes, using Ethernet to connect the satellites to the router is generally considered to provide better performance than the normal WiFi connection.
2. Customers turn to community forums when they have a problem, not when they are happy. When I browse forums for most brands, I do not see a lot of, "so glad I bought this wonderful system." Netgear is no different in that respect.
3. The consensus is that setting up and configuring the system using the web administration procedure is superior to using the Orbi 'app'. Web administration is required for anything past the most basic settings. (with the exception of Parental Controls and Armor, which can be done only through the 'app'.) We 'old-timers' also prefer using a computer connected to the router with an Ethernet cable to manage the system, although there appear to be fewer and fewer customers who have computers with Ethernet capability.
nashdm2
Aug 30, 2022Aspirant
Hey, thanks very much for the reply, really appreciate your feedback. I will get on and buy it. Thanks!!!
