AG_2022
Apr 20, 2022Aspirant
HELP with Orbi Mesh WiFi System
Hi I have the NETGEAR Orbi Mesh WiFi System (RBK752) | WiFi 6 Mesh Router with 1 Satellite Extender |WiFi Mesh Whole Home and my supplier is Virgin Media with a Hub 4. I thought I had followed...
Apr 20, 2022Guru - Experienced User
I always seem to see people having issues with the virgin hubs.
What many do is leave the virgin hub in router mode, disable its wifi, and then put the netgears IP address into the virgin hub's DMZ.
If that doesn't work, you could simple leave the virgin hub in router mode, disable its wifi, and put the netgear in access point mode.
Sadly, you do lose some features on the netgear if you do that.
AG_2022
Thank you. So connection wise/wires what does that look like? Between the Virgin HUB and the Orbi router.
- plemansApr 20, 2022Guru - Experienced User
simply from the virgin's lan port to the orbi's wan port.
- AG_2022Apr 20, 2022Aspirant
So does the ethernet cable from Virgin go into Orbi or do you keep the virgin connection and then connect via ethernet between the two?
- FURRYe38Apr 20, 2022Guru - Experienced User
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
