AG_2022
Apr 20, 2022Aspirant
HELP with Orbi Mesh WiFi System
Hi I have the NETGEAR Orbi Mesh WiFi System (RBK752) | WiFi 6 Mesh Router with 1 Satellite Extender |WiFi Mesh Whole Home and my supplier is Virgin Media with a Hub 4. I thought I had followed...
AG_2022
Thank you. So connection wise/wires what does that look like? Between the Virgin HUB and the Orbi router.
Apr 20, 2022Guru - Experienced User
simply from the virgin's lan port to the orbi's wan port.
- AG_2022Apr 20, 2022Aspirant
So does the ethernet cable from Virgin go into Orbi or do you keep the virgin connection and then connect via ethernet between the two?
- FURRYe38Apr 20, 2022Guru - Experienced User
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- AG_2022May 01, 2022Aspirant
Sorry still not there with this. 😔 So I have disabled Wifi on the VirginHub and have my ethernet cable from that to Orbi and have a connection. BUT if I go the app on orbilogin.com I am getting a ' Router Not Found Message'
