arkiema
Oct 12, 2020Aspirant
Help with Orbi WiFi 6 System (RBK752) AX4200 WIFI Speeds
Hello. I have recently purchased and set up the 'Orbi WiFi 6 System (RBK752) AX4200'. Our ISP is Virgin Media 1GB package with supplied hub. I have connected the Orbi router to the VM Hub via etherne...
Mikey94025
Oct 12, 2020Hero
Try following the steps in the Community FAQ: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
- arkiemaOct 13, 2020Aspirant
Thanks Mikey, I spent the evening trying out most of those steps but no success. Do you know if it is sufficient to just have my ISP Hub in modem mode and run the Orbi in router mode instead of AP? For some reason every time I place the Orbi router in AP Mode the whole system crashes on me, the internet disconnects and does not come back until I perform a full reset and reboot.
All wired connections appear fine, ISP wired is about 900mpbs and Orbi wired is about 900mpbs+ as well. It's only when I connect Orbi to a wireless device such as my iPad (newest gen) that the signal drops about 50% to max 450mpbs. Less for iPhone XR and laptop wireless.
- FURRYe38Oct 13, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
If your ISP modem has a built in router already, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
arkiema
