Toph_Bei_Fong
Aug 10, 2023Aspirant
Help with Port Forwarding Error
I'm getting this error when trying to forward ports for my Nvidia Shield devices for PLex The specified port(s) are being used by other configurations. Please check your configurations of Remote ...
- Aug 10, 2023
Port forwarding requires that the internal IP address remain constant. Rather than set a Static IP on the actual device, the recommended practice is to use the Orbi web interface, Advanced Tab, Setup Menu item LAN Setup to reserve (or 'assign') specific IP addresses to devices using their hardware Mac address.
The DHCP 'pool' of addresses to be handed out to other devices is set to a separate range of IP from those that are being reserved for specific devices. With the separation, there is no chance that some device will be assigned an address from the pool that should be given to one of the fixed devices.
Toph_Bei_Fong
So you mean I can go into the orbi and have it reserve an Ip address for each attached device?
If so, is there a tutorial so I don't screw this up?
edit: so you literally just select the device? wow! this thing is great!
Aug 10, 2023Guru - Experienced User
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
https://kb.netgear.com/24092/How-do-I-edit-a-reserved-IP-address-entry-on-my-Nighthawk-router
- Toph_Bei_FongAug 10, 2023AspirantOh man that is even better. Thank you so much
- FURRYe38Aug 10, 2023Guru - Experienced User
đ
