tburba56
May 24, 2023Tutor
Hidden Port Forwarding values RBR760
I changed ISPs to AT&T Fiber. I didn't want to use their equipment as I needed to continue with my Orbi760 with a number of static IP addresses. We did an IP Passthrough from the AT&T modem/router to...
- May 25, 2023
Thanks for spelling it all out for others that may read this later. Your answer is much more straightforward and complete.
I already had it set up with the IP Passthrough. I messed up by not clearing the routing table on the AT&T device by doing a reboot of it with the Orbi disconnected. I should have let the tech do the IP Passthrough AFTER rebooting the AT& T device. The table would have been clean and not forced the 192.168.173.xxx to be reset to 10.0.0.xxx. That's all done now and seems everything is back working again.
I appreciate your insight. Thanks again.
tburba56
May 25, 2023Tutor
Actually, it turned out to be the AT&T Modem/Router. Once connected to the Orbi, any settings regarding Port forwarding remained in the AT&T device routing table. No wonder I couldn't see them. Once I rebooted the AT&T device, then I could set the port forwards as I needed. Most everything is working. I still have an issue with my Channels DVR and port 8089 when I am away from my house. But I was able to set it. Before I got errors it was already set. I'll have to dink around with that on something other than my cell. I may not have enough bandwidth on my mobile to run TV over cellular. May have to be wifi only.
Thanks for responding
May 25, 2023Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Then you won't need to do any PF configurations on the RBR. Or use AP mode on the Orbi system.
- tburba56May 25, 2023Tutor
I appreciate your insight. Thanks again.- FURRYe38May 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
