tburba56
May 24, 2023Tutor
Hidden Port Forwarding values RBR760
I changed ISPs to AT&T Fiber. I didn't want to use their equipment as I needed to continue with my Orbi760 with a number of static IP addresses. We did an IP Passthrough from the AT&T modem/router to...
- May 25, 2023
Thanks for spelling it all out for others that may read this later. Your answer is much more straightforward and complete.
I already had it set up with the IP Passthrough. I messed up by not clearing the routing table on the AT&T device by doing a reboot of it with the Orbi disconnected. I should have let the tech do the IP Passthrough AFTER rebooting the AT& T device. The table would have been clean and not forced the 192.168.173.xxx to be reset to 10.0.0.xxx. That's all done now and seems everything is back working again.
I appreciate your insight. Thanks again.
tburba56
May 25, 2023Tutor
May 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
