mbt90
Jun 15, 2023Tutor
High ping on when connected to router, normal when connected to satellite
Setup: RBR750 -wired- RBS750 I'm experiencing high ping when connected to router, but normal ping when connected to satellite. I've been searching, but haven't been able to find others with this ...
Jun 17, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is this ping test done with wireless or ethernet connected PC?
Did you turn OFF the RBS before testing with the RBR?
How many RBS are deployed?
What channel configurations are currently set on the RBR?
- mbt90Jun 17, 2023Tutor
Thanks for the reply. Just to make it clear, this seems to be a wireless issue. A speaker connected to router by ethernet cable seems to be working fine. Can do more thorough testing later though.
What Firmware version is currently loaded? V4.6.14.3_2.3.12
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It's a Nokia G-041G-P. Can't find any information when trying to search the model number on google.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Thanks. However there seems to be a fine connection between them. No problem when connected to satelliteIs this ping test done with wireless or ethernet connected PC? Wireless
Did you turn OFF the RBS before testing with the RBR? Nope I did not.
How many RBS are deployed? Just one satellite.
What is the size of your home? Sq Ft? 1345
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. There is more than 30 feet. Haven't measured it exactly.What channel configurations are currently set on the RBR? 2.4 GHz - Auto, 5 GHz - 48
Kind regards, and thanks for trying to help! 🙂
- FURRYe38Jun 18, 2023Guru - Experienced User
Try pings with RBS turned off and with a wired PC connected to the RBR.
For the size of home might try running just the RBR.
Or turn down the power to 50% on the RBR.Might also try some beta FW as well being offered by NG:
- mbt90Jul 28, 2023Tutor
Hi again, sorry for taking so long to answer. Still an issue though, however not everyday.
I've applied for beta firmware, so I guess I'll receive a link or something similar at some point?
I've tried turning down power on RBR which didn't fix it. Turning off RBS is not an option as our home is quite rectangular with concrete walls. We have a RBR in one end and RBS in the other end.
I tried connecting to the satellite and saw the status below. Shouldn't the router and satellite be connected wirelessly also besides a wired connection?
Kind regards
