TWang1337
Jan 21, 2022Apprentice
Hooking up RBS350 to RBR750
I have an RBR750 + RBS750 firstly i up RBR750 + RBS750 = v4.6.5.14 I also have an RBS350 which i've tried to hook up (which is supported by RBR750 on 4.6.5.14) initially RBS350 is v4.4.0.10 t...
CrimpOn
Jan 21, 2022Guru - Experienced User
Unless I am wildly mistaken, the RBS350 satellite does not interoperate with the 750 series product. The 350 is a "dual band" product and the 750 is a "tri band" product. The product data sheet for the RBS350 says "what do I need...." and the answer is a RBR350 router.
TWang1337
Support was added!
RBR750 / RBS750 Firmware Version 4.6.5.14
Was this article helpful? Yes No | 10 people found this helpful in last 30 days
Enhancements:
Adds support for the RBS350
Security Fixes:
Fixes security vulnerabilities.
Enhancements:
Security Fixes:
- CrimpOnJan 22, 2022Guru - Experienced User
How cool. My Bad. Since the new V4.6.7.5 is not a 'public release' yet for the 750, I would imagine that a similar release for the RBS350 would have to come through the same informal channel as the release for the 750.
Good Luck
- TWang1337Jan 22, 2022Apprentice
FURRYe38 do you happen to have ability to access to V4.6.7.5 for RBS350
- FURRYe38Jan 22, 2022Guru - Experienced User
I don't.
Try syncing the RBS3 series the 7 series RBR. Press the sync button on the RBS first then RBR. Do this while the RBS is in same room as the RBR. Give it 5 minutes or so to see if the front LED on the RBS turns BLUE.
What is the distance between the RBS3 and RBR750?
