TWang1337
Jan 21, 2022Apprentice
Hooking up RBS350 to RBR750
I have an RBR750 + RBS750 firstly i up RBR750 + RBS750 = v4.6.5.14 I also have an RBS350 which i've tried to hook up (which is supported by RBR750 on 4.6.5.14) initially RBS350 is v4.4.0.10 t...
TWang1337
Support was added!
RBR750 / RBS750 Firmware Version 4.6.5.14
Was this article helpful? Yes No | 10 people found this helpful in last 30 days
Enhancements:
Adds support for the RBS350
Security Fixes:
Fixes security vulnerabilities.
Enhancements:
Security Fixes:
CrimpOn
Jan 22, 2022Guru - Experienced User
How cool. My Bad. Since the new V4.6.7.5 is not a 'public release' yet for the 750, I would imagine that a similar release for the RBS350 would have to come through the same informal channel as the release for the 750.
Good Luck
- TWang1337Jan 22, 2022Apprentice
FURRYe38 do you happen to have ability to access to V4.6.7.5 for RBS350
- FURRYe38Jan 22, 2022Guru - Experienced User
I don't.
Try syncing the RBS3 series the 7 series RBR. Press the sync button on the RBS first then RBR. Do this while the RBS is in same room as the RBR. Give it 5 minutes or so to see if the front LED on the RBS turns BLUE.
What is the distance between the RBS3 and RBR750?
- TWang1337Jan 23, 2022Apprentice
it connects but sometimes drops out of sync unfortunately
it's not that far. 10m with direct line of sight (i have an AX210 card in my laptop and to the router - i get 20-30mb/s
i think it's a buggy firmware
wold love to use the same firmware for RBS3 and 7!
