sheppp
May 19, 2022Star
How can I match the firmware between the two when the latest firmware
RE: "Yes. Just ensure the FW is the same on the RBS as what's loaded on the RBR.":
I, too, am having problems getting my newer RBR760 (router) to recognize an older RBS750 (satellite).
-How can I...
CrimpOn
May 19, 2022Guru - Experienced User
If "newer" means "purchased less than 90 days ago", then you are entitled to contact Netgear support directly.
It is not entirely clear (to me) what process was used to connect the older RBS750 satellites to the new router.
i.e. Used the "Add a satellite" option on the Orbi web administration menu?
On the original Orbi systems, many users connected up to six satellites to a single router, but ran into a 'situation' with the process because it was designed to display only three satellites at a time. The workaround was to:
- Temporarily power off one of the existing satellites.
- Ignore the message on the Attached Devices screen, "Satellite missing. Want to delete it?" (No, No, No.)
- Add the new satellite.
- After the new satellite is working, power up the original satellite. Voila! Now there are four.
- To add the fifth satellite, two had to be powered off. Follow the process. Power all back on.
- To add the sixth satellite, three had to be powered off.
It was a limitation on the "Add a satellite web code". The Attached Devices page was happy to show all of them.
sheppp
May 19, 2022Star
Thanks for the assistance and detailed instructions! Thus far, I'm not getting any sync love connecting the older satellite with the new router - even after disconnecting one of the newer satellites. Yes, I purchased the new router(s) yesterday. Thus, I will reach out to the Netgear "support" team. Hopefully it will be a better experience than when I dealt with them several years ago re my RBR50. I will keep you posted re my findings when I get some more time in the next day or so to call them.
