sheppp
May 19, 2022Star
How can I match the firmware between the two when the latest firmware
RE: "Yes. Just ensure the FW is the same on the RBS as what's loaded on the RBR.":
I, too, am having problems getting my newer RBR760 (router) to recognize an older RBS750 (satellite).
-How can I...
JStevensJWSP
Jun 22, 2022Aspirant
So, I'm throwing a wrench into the compatibility of rbs 750 with the rbk763 system.
The overall concensus is no its not. Howwever, I'm able to see my rbs750 (attached via ethernet cable to the rbr760) listed in my attached devices when logging into my router main page. Curious if that means it does indeed work?
I'll attempt to connect my laptop directly to the satellite later and see what's what.
