javiersalasf
Mar 15, 2025Aspirant
How can I tie my device to connect to specific satellite?
Hi all, I have a playstation 5 and is 5 ft away from the nearest satellite, when I turn it on, it always connect to the router that is far away (around 26-29 ft away) instead of the nearest satel...
javiersalasf
Mar 17, 2025Aspirant
House is 1600 sq ft, nearest satellite is 6 ft at max, router is at 26 to 29 ft away from the PS5, I have changed again signal from 50% to 100% and seems is working better, I see it connects more ofter to satellite, but sometimes it connects to router
Mar 17, 2025Guru - Experienced User
Can you get the RBS a bit farther away from the RBR.
Also try 25% as well.
