clovehitch
Feb 03, 2022Aspirant
How can I turn off auto updates on an Orbi RBR750?
I'm having random router reboots of my Orbi RBR750 that I suspect is related to auto firmware updates. Does the router do auto firmware updates? Any ideas how to turn off auto firmware updates?
- Feb 04, 2022
I would review this:
Current released FW has known problems for lots of users. This pre-release seems to have helped get better results.
CrimpOn
Feb 03, 2022Guru - Experienced User
Could you please provide more detail. Orbi routers check for firmware update at regular intervals (multiple times per day for some models). Have you observed that the firmware version actually changes when there is a random reboot. Or, do you suspect that the process of looking for firmware updates itself is causing the router to reboot? If that were the case, then every Orbi router would be rebooting multiple times per day.
- clovehitchFeb 03, 2022AspirantI have an RBS750 and 3 RBK750 satellites. I know it is not updating firmware because the version is current. However, the router reboots randomly, as often as once a day. Sometimes while I’m working and sometimes in the evening. There is no pattern. Sometimes I go weeks without an interruption, sometimes I am interrupted daily.
The log file just indicates a restart from what I can tell.
Hope this helps.- FURRYe38Feb 03, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡- clovehitchFeb 04, 2022Aspirant
- Firmware version: V4.6.5.14_2.0.54
- I have Verzion FIOS 1000↓/1000↑ service with their modem/ONT but I do not have access to the device to get the model #
- Building is 80' long and narrow. Router is located 1//3 distance from one end on main floor
- Distance between routers and satellites are at least 30'
- One router is in the basement
- One router is upstairs
- One router is at other end of house connected via ethernet cable because it is too far from the router or other satellites to get a decent signal
- 42 devices connected
It is possible that the firmware update checks are not th eproblem, but I am at my wits end as to what it might be.
- CrimpOnFeb 03, 2022Guru - Experienced User
Hope this helps.Well, it helps indicate (to me) that firmware update is not the cause of the spontaneous reboots. There are other posts in the forum describing issues with the 750 product. (I do not own one, and thus have not watched those posts closely, but I have an impression that there might be a test version of firmware that is being tried by some users. Perhaps that might be a more useful direction than trying to block firmware updates.)
