dandrewk
May 10, 2022Follower
How can we manually update firmware if we can't reach the router's settings
How can we manually update firmware if we can't reach the router's settings? This is the crux of the issue.
May 10, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Disconnect the RBR from the ISP Modem/ONT. Wait for the WHITE led to slowly pulsate in front the RBR, then log in to 192.168.1.1 or orbilogin.com using a web browser and walk thru the setup wizard.
