CrimpOn's avatar
CrimpOn
How Capture WAN Traffic?
A trivia question:  Does the AX model have a "debug" page with the option to Capture LAN/WAN traffic?  What are the storage options?  With my (ancient) original Orbi RBR50, I have plugged in a 32GB U...
  • FURRYe38's avatar
    You are correct. Only system memory which will out put to a .zip file on your PC when you go to collect it.
