switters
Jan 09, 2024Apprentice
How do I adjust RIP settings on RBRE960 router?
I'm having a hard time connecting some Elgato Key Lights to my network. I did some research on r/elgato, and several users said the solution is to enable RIP (routing information protocol) in the rou...
- Jan 09, 2024
The Orbi app does not provide access to any "advanced" functions. Settings for RIP can be found on the orbi web interface http://orbilogin.net Advanced Tab:
p.s. Most "Internet of Things" (IoT) devices work just fine without changing any of the default Orbi settings.
switters
Unfortunately, the Elgato Key Lights are notoriously finicky to set up and get connected to WiFi. I tried connecting them to the IoT network but that did't work.
Jan 09, 2024Guru - Experienced User
Something to contact the Mfr of these devices then since it's there product.
