switters
Jan 10, 2024Apprentice
How do I adjust RIP settings on RBRE960 router?
I'm having a hard time connecting some Elgato Key Lights to my network. I did some research on r/elgato, and several users said the solution is to enable RIP (routing information protocol) in the rou...
- Jan 10, 2024
The Orbi app does not provide access to any "advanced" functions. Settings for RIP can be found on the orbi web interface http://orbilogin.net Advanced Tab:
p.s. Most "Internet of Things" (IoT) devices work just fine without changing any of the default Orbi settings.
Jan 11, 2024Guru - Experienced User
Get you one of these as a wired AP connected to the back of the RBR.
Doesn't have to be new, get one of the used ones. I've bought a few used NG routers off amazon. Work well.
switters
Jan 11, 2024Apprentice
Thanks again! It looks like I just need to turn off the "SmartConnect" feature to get separate 2.4 and 5.0 GHz bands.
The Logitech Litra lights will arrive tomorrow. I'll compare them with the Elgato Key Lights I have. If these work well, they're probably the best solution because I got them for not much more than the cost of the Nighthawk access point, and I can use them without setting up an additional network.
The Key Lights (Mark II) will arrive next Wed. If they connect right away to my existing network and produce much better light than the Logitech Litra, then I'll have to decide whether the $200 difference (between what I spent on them vs. what I'd spend on the Nighthawk) is worth it.
I really appreciate your help. Thank you!
- FURRYe38Jan 11, 2024Guru - Experienced User
On the 2ndary router? Yes, Since it's a non MESH router, it has the ability to disable Smart Connect and disable 5Ghz as well.
Let us know how things work out.
