hennenhoe
Jan 31, 2024Aspirant
how do i connect my printer via orbi wifi 6
HP laser printer MFP 283, orbi wifi 6 I tried a cable to the satellite unit, tried wireless . Printer offline. I want the print to be always on line. What do I need to do. Modem is cable...
CrimpOn
Jan 31, 2024Guru - Experienced User
This printer specs clearly show that it supports two networks connections:
- 10/100 Ethernet cable
- WiFi 802.11n 2.4G/5G
If the printer is connected to a satellite with an Ethernet cable, it should appear on the Orbi web interface Attached Devices display or the Orbi 'app' Connected Devices list with an IP address.
In order for devices to use the printer, they will have to be configured to use it. Windows, Mac, Apple iOS, and Android have specific procedures to "Add a Printer".
What device is being used to access the printer?
- hennenhoeFeb 05, 2024Aspirant
The printer I use is HP MFP 283fdw
The app show it connected if I connect to my computer or if I don't use a enthernet cable it show ii is connected via wireless. However in the wireless mode it is offline all the time. In the wired mode it works for my computer but not my wife's.
- CrimpOnFeb 05, 2024Guru - Experienced User
If it works for your computer when wired to the router, then "it works". The wife's computer needs to be reconfigured to find the printer.
