hennenhoe
Jan 31, 2024Aspirant
how do i connect my printer via orbi wifi 6
HP laser printer MFP 283, orbi wifi 6 I tried a cable to the satellite unit, tried wireless . Printer offline. I want the print to be always on line. What do I need to do. Modem is cable...
hennenhoe
Feb 05, 2024Aspirant
The printer I use is HP MFP 283fdw
The app show it connected if I connect to my computer or if I don't use a enthernet cable it show ii is connected via wireless. However in the wireless mode it is offline all the time. In the wired mode it works for my computer but not my wife's.
CrimpOn
Feb 05, 2024Guru - Experienced User
If it works for your computer when wired to the router, then "it works". The wife's computer needs to be reconfigured to find the printer.
