GoldenDawgs
Oct 10, 2020Follower
How do I daisy Chain a RBR750 system
I have a RBR750. Satellite 1 is 45 feet from router. Sat 2 is 65 feet. On a speedtest I get 500-600mbps on the router and only 90 on Sat 2. I want to daisy chain sat2 to Sat 1. I can't find direction...
Oct 10, 2020Guru - Experienced User
Placement of the RBS out in a line from the RBR and turned then neared RBS on first, then turn on the next RBSs after that will confiigure Daisy Chain.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
