GoldenDawgs
Oct 10, 2020Follower
How do I daisy Chain a RBR750 system
I have a RBR750. Satellite 1 is 45 feet from router. Sat 2 is 65 feet. On a speedtest I get 500-600mbps on the router and only 90 on Sat 2. I want to daisy chain sat2 to Sat 1. I can't find direction...
Mstrbig
Oct 11, 2020Master
GoldenDawgs wrote:I have a RBR750. Satellite 1 is 45 feet from router. Sat 2 is 65 feet. On a speedtest I get 500-600mbps on the router and only 90 on Sat 2. I want to daisy chain sat2 to Sat 1. I can't find directions for that. How do I do it.
- Launch a web browser from a computer or mobile device that is connected to your Orbi network.
- Enter http://orbilogin.com. A login window displays.
- Enter the user name and password.
The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive. The BASIC Home page displays. - Select Attached Devices. The Attached Devices page displays.
If your Orbi WiFi System is using daisy chain, your Orbi satellite displays the MAC address of your other Orbi satellite in the Connected Orbi field on the Attached Devices page:
Oct 11, 2020Guru - Experienced User
You can also check with the Orbi app on a phone or pad.
Under Network.
If you see the connection between the RBR and RBS all in a single line displayed on the Networking page, then the configuration is in Daisy Chain.
If you see the RBR each connected to the RBR directly, then is this called Star configuration and is not in Daisy Chain configuration.
