Mickeytheone
Oct 30, 2020Aspirant
How do I enable my smart plugs to connect to the dual band WiFi
I have just installed the Orbi 853 system and it is broadcasting a dual band 5/2.4 ghz WiFi signal - my Amazon and how-link smart plugs need to be able to see an independent 2.4 signal in order to be...
Mickeytheone
Nov 02, 2020Aspirant
Further to my question, turns out everything was actually okay.
In my house I have the tp-link and one Amazon plug and also a Siemens tumble drier and an Aria Fitbit scale, all working on 2.4ghz - having tried to connect the tp-link plugs and failed, I tried the Amazon plug and low and behold it worked!!! Then did the tp-link plugs and they worked too. Then did the Aria, success!! Then did the Siemens, which was much more complicated using Home Connect, and it worked too.
It seems that, actually, the Orbi 853 system was able to identify what the different devices require to connect to and match it - great relief in my house!!!!!
Instructions to turn on the lights work again and the scales tell the Fitbit app about my weight - well done Netgear!!
- FURRYe38Nov 02, 2020Guru - Experienced User
Good to hear, Glad its all working. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark your thread and solved so others will know.
Enjoy. :smileywink:
