tteboe
Sep 03, 2021Initiate
How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway
How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway The AT&T Network sees the CBR750 But I don't get a wirless transmission and the Cable Modem Router and light stays Magneta a...
Sep 03, 2021Guru - Experienced User
The CBR750 is a cable modem.
Att is fibre. Not cable.
And as far as I'm aware, the CBR750 doesn't have a router only mode.
tteboe
bgw-32AT&T is replacing the Spectrum service
I thought once I disconnected the Coaxial cable and used the RJ45 cables to connect between the AT&T BGW-320-505 and the Orbi CBR750 there would be pass thru communication. So I need to replace the CBR750 with a non Router version to be operational.
Do you happen to know what master I could use to work with the my current satillites ?
- CrimpOnSep 03, 2021Guru - Experienced User
RBR750
- FURRYe38Sep 03, 2021Guru - Experienced User
The CBR works on Cable ISP services. I don't believe ATT uses cable modems or there services.
Please contact the ISP to see what they support ON there ISP service. An RBK series MESH system will work with the ATT modem though...
