tteboe
Sep 03, 2021Initiate
How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway
How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway The AT&T Network sees the CBR750 But I don't get a wirless transmission and the Cable Modem Router and light stays Magneta a...
tteboe
bgw-32AT&T is replacing the Spectrum service
I thought once I disconnected the Coaxial cable and used the RJ45 cables to connect between the AT&T BGW-320-505 and the Orbi CBR750 there would be pass thru communication. So I need to replace the CBR750 with a non Router version to be operational.
Do you happen to know what master I could use to work with the my current satillites ?
CrimpOn
Sep 03, 2021Guru - Experienced User
RBR750
