kryspin34's avatar
kryspin34
How do I set up my Orbi as an access point?
Hello,
I just received my Orbi RBK753, and I want to set it up as an access point in order for my IPTV to work, but I can't find this option on the orbilogin page. When I go to advanced settings, it basically shows me a blank page. What do I have to do now?
1 Reply
  • Okay, so I opened the page on Firefox and it worked.
    I have another issue though.
    I have main rotuer and 2 satellites. I live in a 3-storey bulding. My ISP provides me with 600mbps fiber. The router is connected to modem on the attic, the first satellite is on the 1st floor and I'm able to get around 100mbps, due to thick ceiling made of concrete with steel rods to fortify it (couple layers, but only the first layer has metal rods, styrofoam and pipes filled with water from floor heating. I put the 3rd satellite on the ground level and via wi-fi I was able to get around 50mbps, then I connected satellite to my laptop via ethernet cable. The results were similar, but I noticed that my phone isn't connecting to the satellite from the ground floor, but from the 1st floor. Now it constantly connects to the satellite on the 1st floor and the app says that the ground level satellite is disconnected. Although when I connect my laptop to the ground level satellite, I'm getting internet connection and around 20-30mbps. What's the problem?
