flyerBob
Jun 11, 2021Aspirant
How do I split 2.4 GHz and 5 GHz?
I have devices that need a 2.4 GHZ ONLY network.
How do I split the 5 and 2.4 GHz networks?
Orbi doesn't support separation of SSIDs.
What model Orbi do you have?
- flyerBobAspirant
So my devices are permanently locked out?
Not sure if that model is correct - what pulls up is RBR 750 with the interface
No. Devices should connect. You can use same SSID name and PW On Orbi as used on any prior router. Its up to the wifi devices to pick and choose which signal they connect too. For 2.4Ghz only devices, they will never see or connect to 5Ghz signals.
