JimmyBSwe
Mar 11, 2024Aspirant
How do I turn my Orbi RBR350 into a Access Point?
Hello! I already think this thread exists but I can't find it! I would like to turn my Orbi RBR350 router into an Access Point but can't find a guide on how to do this.Today I have an RBR750 as ...
- Mar 11, 2024
JimmyBSwe wrote:
I can connect my games and tv devices to the main router via network cable through the RBR350, the RBR350 will not be used for anything else, I don't even want it to send out any signal so other devices can connect to it wirelessly.. Is this possible or not?
A $20 gigabit Ethernet switch will be a cleaner solution, plus offer more ports (8 ports instead of 3), and take up less space.
It is impossible to disable the WiFi radios on Orbi equipment. (They are, after all, WiFi routers.) What you could do is:
- Change the 2.4G and 5G channels to as far as possible from the 750 as possible.
- Go to the Advanced Tab, Advanced Settings, Wireless Settings and change the Transmit Power setting to the smallest possible value (which I think is 25%)
I would go with the Ethernet switch
